I have a Thermaltake Water 3.0 RGB AIO CPU cooler and it's a bit different to set up vs others I've had. I'm building my first mini-itx build in a Corsair 250D with a Gigabyte H170N WIFI motherboard.
You're supposed to plug both of the rad fans into a controller that allows you to change the LED colors of the fans etc. It has a 4 pin out that goes to the sys fan header. Then you plug the pump into the CPU fan header. Problem is I'm out of fanheaders now for the intake fan and exhaust fans. I had jerryrigged a solution but i think this will be cleaner.
So the question is if I buy a splitter can I run the fans and the pump off the sys fan header?
