Using the Antec 200mm radiator, safe or not?
Aleckazee
134
I'm looking for a 200mm radiator to place in my corsair 650D (will be putting it where the front 200mm intake fan is). Apart from that I will put a dual 120mm rad at the top of the case (but still inside). The problem is, I can only find 2 200mm rads, the Phobya Xtreme (which is out of stock) and the Antec 200mm which is made of aluminum and I've heard that is a big no no for water cooling.
I can't find the Phobya Xtreme anywhere else and it has been out of stock for a while on frozencpu.
Can I just use the Antec? And if not do you know anywhere I could get the Phobya or any other 200mm rad online? They would need to ship to Australia tho.
