Using two networks for different purposes
Asbaat
305
Hi, I have a DSL broadband and a 4G LTE connection. I want to use the DSL for the ping in online games and the 4G USB Dongle for the upload speed. Is there any way I can do this.
Ping from DSL
Upload Speed From 4G
Only to a point and with a lot of effort. The usage must actually be different. You can not for example use both connection to play the same game. You could though use one to play the game and the other to connect to a voice com server.
This is all done via the ROUTE command. The hard part is getting the lists of IP you want to use the secondary connection. You are going to have to key them all in which is where all the work comes in. If you can keep it to a small list it will work.
Be careful though 4g connections tend to have many limitations on them the largest being caps on bandwidth usage.
Yeah i know its gonna be hard, anyways, **** the idea, I'll instead play with high ping.
