Question Using VSR without Adrenaline ?
Dec 13, 2018
73
CPU: RYZEN 7 2700X
GPU: RX 6750 XT
I have faced driver timeouts and other Adrenaline related crashes so I decided to only use the driver but not the adrenaline software. But the problem is my MONITOR is 1080p and i want to enable VSR.
So i tried installing adrenaline then turn VSR on thru the software, then went to hkey.local.machine and hkey.current.user in the registry and exported the "AMD" registry folder then used DDU to uninstall driver and then reinstall "driver only". After that I imported those registry files by double clicking on it and went back to regedit and everything was in place.
But this isn't working, resolution won't go beyond 1080p. Is there any other way to do it?
