Using XCOPY
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
In using XCOPY C:\a\b\c\d..... etcetera etcetera .....
is there a limit as to how many subfolders deep
it can work? For example, to be specific,
Will it object to
XCOPY C:\temp\temp1\temp2\temp3\temp4\temp5\temp6\temp7\temp8 D:\
Thanks....
William B. Lurie
"William B. Lurie" <billurie@nospam.org> wrote in message
news:##CXQ79yEHA.1264@TK2MSFTNGP12.phx.gbl...
> Will it object to
> Thanks....
> William B. Lurie
What prevents you from trying it to see what happens?
> Will it object to
> Thanks....
I think total string length must be less than 127 bytes.
>> Will it object to
>> Thanks....
Thank you, Rick. I'll ask in a Microsoft group as to
detailed instructions. I didn't see it in the explanation
of the /modifiers.
William B. Lurie
news:#wPFEN#yEHA.2788@TK2MSFTNGP15.phx.gbl...
> >> Will it object to
> >> Thanks....
> of the /modifiers.
> William B. Lurie
The command line string may include up to 8191 characters in XP--see the
following KB article:
http://support.microsoft.com/default.aspx?scid=kb;en-us;830473
William
Take a look at this page.. it shows which switch is used to copy
subfolders..
http://support.microsoft.com/?kbid=289483
Mike
news:%23%23CXQ79yEHA.1264@TK2MSFTNGP12.phx.gbl...
> Will it object to
> Thanks....
> William B. Lurie
Mike Hall wrote:
> William
> subfolders..
> Mike
A better source is the XP Help and Support. There have been a few changes
with the XP command line. Just type xcopy in H&S.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
>>>>Will it object to
>>>>Thanks....
>>of the /modifiers.
>> William B. Lurie
Thank you, Ray and Mike for the referrals.
I needed that assurance, although making it function
is still up to the actual operator....
William B. Lurie
Will remember that.. ty
"Ronnie Vernon MVP" <ronv@mvps.org> wrote in message
news:eT1Q1mAzEHA.352@TK2MSFTNGP14.phx.gbl...
> Mike Hall wrote:
>> William
>> subfolders..
>> Mike
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
Here you go again wasting bandwidth. Lets look at your decietful behaviour.
1. You give a false example.
2. You aren't mentioning you are looking at XCopy because you are too stupid to back up mail files. You can't be helped on your mail files because you are too stupid to say what you are doing. You prefer to start pointless threads as there is no information only idiots answer (re several idiots talking about SP2 as if it matters and third party burning when itr's OPERATOR ERROR AND STUPIDITY.
http://www.uscricket.com
"William B. Lurie" <billurie@nospam.org> wrote in message news:e99fxE$yEHA.908@TK2MSFTNGP11.phx.gbl...
>>>>>Will it object to
>>>>>Thanks....
>>>of the /modifiers.
>>> William B. Lurie
> William B. Lurie
Last message...honest:
My credentials are that I had an I.Q. of 189 in the days
when those tests meant anything, and graduated from
Yale when I was 18...... I'll match my stupidity aginst
yours, sight unseen, David. Try being helpful instead
of snotty.
William B. Lurie
news:#5pYzfBzEHA.2200@TK2MSFTNGP09.phx.gbl...
behaviour.
> of snotty.
> William B. Lurie
Not that I necessarily want to get in the middle of anything here, but I
have a relative who graduated from law school while still in his teens, was
a college president in his early twenties, and was dead from an overdose of
an opiate before he was thirty. Our current president is also a Yale grad,
so that doesn't seem to be much of a recommendation either.
