Hello everyone
I know the title isn'nt very clear so I'll be a little more specific. It's a vaio PCG-91211M and when I boot it up I get a blackscreen with the message "operating system not found". I can't install windows 10 on it because for all partitions (even when the drive is formatted and all partition cleared) windows says the os cant be intall on it because of the GPT.
Since it's not my pc and my works fine, I installed windows 10 on the sony drive from my own laptop and it worked fine. I also put my laptop's drive inside the vaio and I get the same result.
After installing a fresh windows ans testing it on my laptop I put it back inside the vaio and nothing changed.
I saw some things about switch the SATA controller to IDE instead of AHCI but the BIOS is completely locked. I can only change date and time and boot order. I could maybe reinstall the AHCI driver but I have no idea how to do so.
TL;DR
-vaio boot : operating system not found
-can't install win 10 : Problem with GPT
-install on sony drive from other PC --> works fine
-put it back in vaio --> same thing
- please help ^^
I'm quite handy with tech issues but I'm stuck on this one since I don't understand the cause.
Thanks in advance
TL;DR
- please help ^^
Thanks in advance
