My specs if it helps:
CPU: Ryzen 9 5950X
Motherboard: X570 Aorus Elite
Ram: Corsair Vengeance RGB Pro 64GB 4x16GB DDR4 3600MHz
GPU: Gigabyte Vision RTX 3080
Case: NZXT H510 Elite
Hi everybody, I have a question regarding a vertical GPU mount. So yesterday I bought the Phanteks vertical GPU mount kit and I was very excited to mount it only to find out the graphics card wasn't outputting any video and the system would not boot and make a GPU error sound. I thought the riser might've been damaged but I tried it with another system and GPU and it works just fine. Then I thought maybe the GPU is too powerful for it but there are people with 3090s using it so that could not be the problem. Do you have any ideas on how to fix the problem? I'm am afraid of breaking my GPU because I know faulty risers can break them
CPU: Ryzen 9 5950X
