Very puzzling problem
David
2,039
Archived from groups: alt.sys.pc-clone.dell,alt.os.windows-xp,comp.sys.laptops (More info?)
The keyboard on my Dell the letters "H' and "I" do not work on the runline
but do work normal in office. The OS is XP? Any advice?
TIA,
David
What's "the runline?"
Notan
Notan <notan@ddress.com> wrote in news:431F7699.A1FB1960@ddress.com:
>> runline but do work normal in office. The OS is XP? Any advice?
> Notan
Start-> Run
Command Line?
If you are talking about the start-run box, you might post this in the
WinXP group.
Otherwise, do they work in notepad and in a CMD window?
Are there any assigned uses for the keys, like shortcuts or special uses
in some software? Have you checked to make sure you have the correct
keyboard set up?
Turn the keyboard over and shake it to see if anything falls out! 😉
Clark
>>Notan
> Start-> Run
> Command Line?
"Clark" <who@whoknows.com> wrote in message
news:qiMTe.4217$wk6.2616@newssvr11.news.prodigy.com...
> WinXP group.
> keyboard set up?
> Clark
Also, for S&G check the function while in safe mode.
Stew
