G
Guest
Guest
My head goes crazy.... I got ASUS KT133 A7V M-Board (200FSB)800Mhz Athlon T-Bard and 192(2 modules , 1 is 64MB and another one is 128MB, both of them say pc133) of Kingmax (Tiny BGA) pc133 (7.5ns) RAM which works fine only at DRAM FREQUENCY 100(BIOS settings)! When I put DRAM Frequency at 133 computer crashes in 3-10 minutes. Why? I tried to plug them in different DIMM slots on the motherboard - same results. The UNUSUAL problem is that when I pull out one of the modules(64MB or 128) it works FINE at DRAM FREQUENCY 133, so I can work only with 128MB OR 64MB at pc133... How can I make my RAM work at pc133 with both modules (even at DRAM FRequency 100 192 of RAM is better then 128...) Help.
Thank You.
Thank You.
