Question VGA light after restart
4
About a month ago I built a new PC and everything was running properly for about 3 weeks. Then one morning I booted the PC and the screen stayed black and the motherboard displayed the red VGA light, I proceeded to reseat the GPU which seemed to resolve the issue. However whenever the PC restarts the same issue occurs and I have to reseat the GPU again to get a display. Not sure if the issue lies with the motherboard or GPU since both a relatively new. I think that it is odd that it only happens when the PC is restarted and when the PC is shut down and turned on again, it boots properly.
Specs:
Motherboard: MSI MAG B550 Tomahawk
GPU: Nvidia Geforce RTX 3060 Ti
CPU: AMD Ryzen 5 5600x
RAM: Corsair Vengance PRO (2x16gb) 3600mhz
PSU: Corsair RM750 ATX 80 Plus Gold
NZXT Kraken 53x 240mm
Case: Lian Li Lancool 205 Mesh C
UserBenchmarks: Game 138%, Desk 108%, Work 126%
CPU: AMD Ryzen 5 5600X - 103.9%
GPU: Nvidia RTX 3060-Ti - 131.2%
SSD: WD Black SN770 NVMe PCIe M.2 1TB - 553%
SSD: Samsung 980 NVMe PCIe M.2 500GB - 304.8%
RAM: Corsair CMW32GX4M2D3600C18 2x16GB - 107.8%
MBD: MSI MAG B550 TOMAHAWK (MS-7C91)
The PC was built from scratch so all the parts were out of box and brand new when assembled and windows 10 was installed using a USB. Then I installed all the drives and have kept the Nvidia drives up to date since and performing clean installs.
