VGA output on Skylake?
httpinternet
19
http://ark.intel.com/products/88184/Intel-Core-i5-6500-Processor-6M-Cache-up-to-3_60-GHz
Graphics Output eDP/DP/HDMI/DVI
4K Support Yes, at 60Hz
Max Resolution (Intel® WiDi)‡ 1080p
Max Resolution (HDMI 1.4)‡ 4096x2304@24Hz
Max Resolution (DP)‡ 4096x2304@60Hz
Max Resolution (eDP - Integrated Flat Panel)‡ 4096x2304@60Hz
Max Resolution (VGA)‡ N/A
Does this mean that I cannot connect VGA/DVI monitor directly on the motherboard?
Yes, a 2nd vga monitor will require an...
I plan to buy Asus B150M-A.
Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
So can I output to VGA/DVI monitor with this motherboard and i5-6500 CPU?
No, because DVI-D is digital only (VGA is analogue). You'd need a DVI-I socket wit a DVI-VGA adaptor, or a VGA socket on the board.
Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
So I can connect one VGA monitor and I need active convertor (DVI-D to VGA) to connect other VGA monitor?
Yes, a 2nd vga monitor will require an active DVI-D to VGA converter.
Latest posts
