N Nickiel12 Reputable Nov 27, 2015 67 0 4,640 Dec 11, 2017 #1 I am looking into building a computer to run three projectors and was wondering what I should look for on a video card. I am reusing an old system build so it would be using the FX series and M5A97 R2.0 motherboard and 32 GB of ddr3 RAM
T TJ Hooker Titan Ambassador Apr 15, 2014 11,635 1,773 72,390 Dec 11, 2017 #2 What video connectors do the projectors have, and what resolution are they? Upvote 0 Downvote
N Nickiel12 Reputable Nov 27, 2015 67 0 4,640 Dec 11, 2017 #3 TJ Hooker : What video connectors do the projectors have, and what resolution are they? HDMI but there are adapters available for that, and the resolutions are all 1024 x 768 (XGA) Upvote 0 Downvote
T TJ Hooker Titan Ambassador Apr 15, 2014 11,635 1,773 72,390 Dec 11, 2017 #4 If you're ok with using adaptors then pretty much any video card with 3 video outputs would do. Something cheap like a GT 1030, GTX 750, or RX 550. Upvote 0 Downvote
N Nickiel12 Reputable Nov 27, 2015 67 0 4,640 Dec 11, 2017 #5 TJ Hooker : If you're ok with using adaptors then pretty much any video card with 3 video outputs would do. Something cheap like a GT 1030, GTX 750, or RX 550. ok quick update. it turns out that we will be using a Matrox Triplehead2go so i just need one display port thx. Upvote 0 Downvote
