I've been having a problem with a line of artifacts when I play games coming across my screen, and my friend suggested I post here to see if I could find out whats wrong.
I am using a Radeon X800xt and have always played at 1024x768 resolution before I got my new LCD monitor. After getting my new monitor I decided to bump my games up to my monitors native resolution which was 1280x1024 (standard LCD res). I did this to my desktop first and had no problems. I then applied it to CS:S and started to see a line of what I guess are artifacts coming across my screen.
I plugged my old monitor back in to see if it still had artifacts at higher resolutions and it did as well. I also cleaned out all the dust and stuff out of my computer and made sure it wasn't over heating. According to ATI's Catalyst Control center it said it was running at around 70C while playing CS:S. So now I'm completely stumped as to why I have these artifacts in all of my games at higher resolutions but not at lower ones.
Some pics to show...
http://www.postfarm.net/premium/insider/de_dust20001.jpg
In this one you can see the square artifacts showing up on the walls. They almost always show up somewhere along this straight line randomly during play. Sometimes I only see one, sometimes I see dozens. I have occasionaly seen them show up slightly below/above that line but never by much.
http://www.postfarm.net/premium/insider/de_dust20005.jpg
After I took this one I started notice that the artifacts weren't just random colors, but they were actually showing the map PAST the wall. Basically I could see through the wall looking at those little squares. I also noticed that when my hands or gun or knife go over where the squares are, I can no longer see them. Basically the artifacts only appear on walls/objects but not my hands or gun.
http://www.postfarm.net/premium/insider/de_dust20004.jpg
Last one and you can clearly see the red Bomb marker through the barrels. I could also see it through walls/doors but I think you get the idea.
Any help as to what is causing this, and how to fix it would be appreciated. Thanks.
