[SOLVED] Virus / Keylogger pls help lol
malancinas
6
So this has occurred a few times over the last few weeks. Only happens sometimes but does happen and I cant find it with malwarebytes. When it happened just ten minutes ago i instantly did a malwarebytes scan and a few minutes in my PC crashed ://
So what happens is when i (not always) past some type of text instead of just pasting what i copied it also pastes the message:
"onion.live
xxxxxxx"
Where xxxxxx is my computers log in code...
Any advice on removing this?
edit:
I have since the reboot done a malyware bytes scan and nothing came through.
You should be able to change the actions of shortcut keys on your keyboard.
There will be a corsair keyboard app that needs installing(or reinstalling if malware altered it)
If you can't remove it, you can always reinstall windows.
BTW - you do know, what lol means? Right?
Loughing Out Loud. Does your keyloger issue seem like something, you should lough about?
I know what I can and should do but I don't really want a full reset ;(
Tbf maybe its not a key logger or whatever but it has the password to unlock my computer which might not even be that usefull right? :/
onion.live is a dark web site.
Stay away at all costs.
You are exposed to ransomware and worse.
Back up what you value to an external device and reset windows.
It is possible that a virus has also modified your bios.
Nasty, but if the problem reappears, perhaps you can update the bios to remove such a virus.
Ok so i have just figured out kinda what has happened.
I have the corsair keyboard with G1,G2,G3...G6 shortcuts on the left side of my keyboard.
When i press G6 this is when it does the writing of which i now have the full messages:
"spottonion.live
xxxxxx "
xxx for password.
given that it is a shortcut in my keyboard is this still a harm?
