I'm having a problem in Vista Home Premium where the Control Panel either won't open (see the outline of the box, little blue circle, then nothing) or opens w/ nothing but a blank white background (no icons, text, etc.). Also, the Welcome Center no longer opens at start up.
I found this solution which seems to provide only a temporary fix:
click the round vista button.
where it says start search, type "cmd",then enter.
In the dialog box type "services.msc",then enter
Highlight "Software Licencing" and click "restart" in the upper left corner
Highlight "SL UI Notification Service" and click "start" in the upper left corner
Your done!
http://pcadvisor.co.uk/forums/index.cfm?action=showthread&threadid=295889&forumid=20
I had this same problem, I think it's due to one of the latest hot fixes. Anyways, it is quite easy to fix. Goto start-run "services.msc"
Restart Software Licensing, SLUNotify & Readyboost
That should fix your problem.
http://www.hardwarecanucks.com/vista/2138-vista-control-panel-problem.html
Any thoughts or advice?
Your done!
