After hours of searching with absolutely no success, I am forced to seek help here.
My motherboard is a Biostar A770 A2+, and according to the website's BIOS manual (as seen here) and seemingly everyone else that owns this board, there are these options under the CPU features:
--- CPU FEATURES ---
Virtualization: Enabled, Disabled
AMD K8 Cool&Quiet Control: Enabled, Disabled
NPT Fid Control: (x5 - 1000mhz, x6 - 1200mhz, ... , x10 - 2000mhz, x11 - 2200mhz)
NPT Vid Control: Auto, 1.4v, 1.375v, 1.350v, ..., 0.5500v
But this is what mine shows:
AMD CPU Stepping: 0,1
I really want that NPT Vid Control that every other owner of this mobo is able to access. I am dumbfounded as I have updated the bios to the latest version (7/11/08) and am in serious need to up the voltage to 1.35. I mean, surely I must be missing something somewhere. I am able to run my CPU stable (7750 X2 BE) from 2.7 to 3.1, but when I up it to 3.2, which makes crysis run perfect, it crashes crysis after about 5 minutes. I am sure that a small voltage increase (currently at 1.31) would do the trick, but for some reason I can not get the option to do so! WHAT IS GOING ON? Please, I need some help on this, I have no idea where to turn. I came across one other person using Google that had this problem, but his thread died before anyone offered up a solution. I am very desperate.
EDIT: The .exe is from the biostar website and all it does is put 2 .pdf's in your documents folder. The 2nd one is the bios manual. Here's the mobo's page
