Archived from groups: comp.dcom.voice-over-ip (
More info?)
On Sat, 21 Aug 2004 18:13:50 GMT, Cheetoh wrote in
news:10if451diua58c8@corp.supernews.com:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> support@vonage.com is all I used via email and they
> responded...
> "Flatus Ohlfahrt" <flatus@militaryretired.us> wrote in
> message
> news:Xns954C88B73CAEAflatusmilitaryret@130.133.1.4...
>> On Sat, 21 Aug 2004 06:34:56 GMT, Cheetoh wrote in
>> news:10idr89jr1ev410@corp.supernews.com:
>> > Hash: SHA1
>> > So it turns out that the current firmware Vonage is
>> > using on the Cisco ATA186's has a bug that puts a 0x0
>> > value in the IP Precedence field, so instead of sending
>> > voip bearer packets with an IP Precendence 5 they
>> > are sent with 0, like all data. I have worked with them
>> > and they have loaded a test image and it works
>> > like a champ now and my LLQ is working great in case any
>> > one else is trying to do this...
>> > LLQ-router# show voice queuing
>> > Ethernet1
>> > Service-policy output: shape
>> > Class-map: class-default (match-any)
>> > 365625 packets, 66899306 bytes
>> > 30 second offered rate 591000 bps, drop rate 0 bps
>> > Match: any
>> > Traffic Shaping
>> > Target/Average Byte Sustain Excess
>> > Interval
>> > Increment
>> > Rate Limit bits/int bits/int
>> > (ms)
>> > (bytes)
>> > 1100000/1100000 6600 26400 26400
>> > 24
>> > 3300
>> > Adapt Queue Packets Bytes Packets
>> > Bytes
>> > Shaping
>> > Active Depth Delayed
>> > Delayed
>> > Active
>> > - 3 361289 66615027 11338
>> > 13704219 yes
>> > Service-policy : LLQ
>> > Class-map: call-setup (match-all)
>> > 5675 packets, 1804013 bytes
>> > 30 second offered rate 0 bps, drop rate 0 bps
>> > Match: ip precedence 3
>> > Queueing
>> > Output Queue: Conversation 73
>> > Bandwidth 5 (%)
>> > Bandwidth 55 (kbps) Max Threshold 64
>> > (packets) (pkts matched/bytes matched)
>> > 25/8990
>> > (depth/total drops/no-buffer drops) 0/0/0
>> > Class-map: voice (match-all)
>> > 129981 packets, 18261798 bytes
>> > Match: ip precedence 5
>> > Queueing
>> > Strict Priority
>> > Output Queue: Conversation 72
>> > Bandwidth 165 (kbps) Burst 4125 (Bytes)
>> > (pkts matched/bytes matched) 1349/279958
>> > (total drops/bytes drops) 0/0
>> > 229969 packets, 46833495 bytes
>> > 30 second offered rate 592000 bps, drop rate 0
>> > bps Match: any
>> > Queueing
>> > Flow Based Fair Queueing
>> > Maximum Number of Hashed Queues 64
>> > (total queued/total drops/no-buffer drops) 3/0/0
>> So, are they going to make the flash available to whoever
>> wants/needs it? Is there a good point of contact for
>> firmware issues?
>> Flatus
> -----BEGIN PGP SIGNATURE-----
> Version: PGP 8.0.3
> iQA/AwUBQSeQ3OHzPuqqaV5HEQKRDACgzQT9pM7MlbTPNCbybWRIIrjQm7kA
> oLe2 G0mf7DEh0BdVFu2usYhQnZZU
>=ceWK
> -----END PGP SIGNATURE-----
Thanks for this. After your messages, I emailed them and was
told that they flashed my 186 with the new firmware this
morning.
Flatus
