Vu 55 inch android tv connection with bose companion 5 speakers
TV probably has optical audio output. Turn the optical output on. You may have to turn the TV speakers off and change the audio output to PCM in the TV menu. Connect an optical to analog convert with a toslink cable to the TV. Connect a cable with 2 RCA plugs are the converter end and a 3.5mm stereo mini plug at the Bose end. Connect that to the aux input on the Bose.
