Hi there,
I've been trying to set up WOL for a server connected to an offline network. The PC I'm sending the packet from has two ethernet ports.
One port is connected to the router which is connected to the internet and the other port is connected to a switch that then connects to offline servers.
Both ports are Intel(r) l211 Gigabit Network Adapters and all servers and PCs involved are running Windows 10.
The problem is that when I try to send a packet to one of the servers nothing happens because the packet is sent to the interface that's connected to the internet, not the offline one.
When I disable the internet connected interface in the control panel the packet is sent to the offline network and the server wakes up instantly (for example 192.168.1.3 in the below example).
How can I specify which interface to send a magic packet to? (I'm using command line based solutions like WolCmd.exe and WakeMeOnLan.exe) Here is a quick diagram of the setup:
Kind Regards,
Bailey
Kind Regards,
Bailey
