Since the Warzone Season 3 update, I have been having weird texture issues with the Terrain.
When you look at the ground, parts of it will be in black and its the ground texture itself
This only appears to happen with grass/dirt Terrain.
Anything on the Road or Indoors, seems to be fine. Bit odd how its specific only to this type of Terrain
It doesn't always appear but does often and depending on how you look at the ground, how much of it shows is random
I have re-installed the driver, re-installed the game, removed cache and temp files
Reset the shaders, tried running on low, medium and high settings
Tried different graphics and nvidia settings
Not sure what could be causing the problem
Here are my PC specs
AMD Ryzen 5 5600X 6-Core Processor 3.70 GHz
32.0 GB RAM
Nvidia GeForce RTX 3060 Ti
32.0 GB RAM
