Hello. This morning I was doing homework on my computer when it began to act up and be extremely glitchy. I immediately opened coretemp to see it read 80-100c. I then turned the computer off to prevent damage. After restarting a screen from America Megatreands pops up with CPU fan error. It allows me to go into bios and it says my CPU fan is not on and that my temp is 89°c. I looked in my case and my back fan is on and my radiator with two fans for the water cooling are also on. However the coolant isn't pumping in the loop. How do I fix this? Thanks!
Edit: forgot to mention I tried moving the computer around and the tank of coolant is completely full, also I've restored bios defaults.
Update: It definitely seems to be an air block I pinched the tube and it began pumping coolant but then soon returns to the same position with a gap of Air in the middle.
Update 2: It's pumping on and off but stopping a lot at this position: https://imgur.com/hXkGYun
