Hey,
I have a fractal design Celsius S36 cooling my i7 8086k. The thing is, the CPU gets extremely hot sometimes. In winter, when in a cool room, it goes up to about 97C. This was when overclocked to 5.1 GHz at 1.34V. When I tested it with default settings back then the CPU got up to 93C after a 30 minute stress test (Intel Extreme Tuning Utility).
I wrote to fractal support about that a while ago but they told me it is normal and when I said other people only get temps in the mid-80s (mostly with 8700k's) they told me some are better than others, so I just assumed I had lost the silicon lottery.
Now it's summer and I decided to check the temps when playing PUBG and it doesn't look great. Overclocked to 4.8GHz at 1.3V the CPUs cores peak from 91C to 97C. Am I really just unlucky or is something not right after all?
Here is a screenshot of HWMonitor:
The case is a be quiet dark base 700. The cooler is in the top. Is the case maybe too isolated?
Motherboard is an Asus Z370-F Gaming
Is it really normal or should I get a new cooler asap?
Thanks
Thanks
