Hi, I currently have a Corsair H60 liquid cooler (2013 version) strapped into my FX-9590 chip on an AM3+ platform (Gigabyte 990FXA UD3 R5). This particular cooler is 120mm which means smaller radiator and only supports up to 2 fans. As of right now, I am using a Gentle Typhoon 120mm fan in a "push" configuration and are planning to upgrade into a "push-pull" configuration adding the stock Corsair H60 fan for "pull".
The question is, which fan should act as the "push" and "pull" since both are different fans from different manufacturers and has different static pressures. Please do enlighten as I am new to water cooling. Cheers!
