Hello as the title says i have on a EYE the EK a240g Kit and want to buy it to upgrade my PC but its "Aluminium" and i am thinking if its the right way to make Watercooling for PC with that Kit because its only like $250/243-Euro for a CPU and GPU kit with pump Fittings and Pump/Tank... it is very simple i know straight fittings etc no matter for that setup i was thinking about the way system its going guys and i need help with !
most of the Water cooled systems are going in the way of
from the reservoir to the CPU from a CPU to a GPU straight away and because of that heat from CPU water its not cooled for the GPU its straight from a CPU ... i gues it will get close Temp to CPU than ....
and i was thinking to buy another Single aluminium Radiator on Ebay buy 2 fittings form EK and make the way like this the water goes from a reservoir to Radiator and to CPU right and "most setups straight to GPU " and changing the way to from a reservoir to CPU and from CPU to the single Radiator and Thank to GPU back to the reservoir and over again ...
and my question is if it will Cool enough the Water to go to The GPU if someone is getting what i mean my English is really bad im sorry
