Hello guys,
I was thinking about finally jumping on the water cooling train. I would like to cool both gpu and cpu
However, I would need some advice.
Problem n.1 is definitely space. Because I would like to have 280mm front rad (as a start, maybe expand it with some 120m back rad or 240m top rad)
I would like D5 pump with some reservoir, but can it somehow be mounted horizontally? (Under the GPU probably)
I found a full cover block for the GPU (Gigabyte GTX 1080 Ti Gaming 11GB OC) on aliexpress (nowhere else)
Definitely gonna use soft tubes since its first loop
Was thinking about something like this: ( View: https://imgur.com/a/N4vxkrk
BTW the pump and reservoir should be above PSU shroud (if that's not obvious), I would like to leave shroud there if it is anyhow possible)
Any advice is welcome
