Simple AIO coolers like that require pump to run full speed all the time. That's what " AIO_PUMP connector" on the MB is for, plug pump in there.Asus ROG b450-F
Asus ROG b450-FUnfortunately, the manual for that AIO system uses no words, so it's not clear where they recommend you plug it in. Ideally, BOTH the pump unit and the rad fan should be connected to a CPU_FAN or CPU_OPT header, and there are ways to do that, depending on what your mobo has. Tell us the maker and exact model of your mobo so we can look up its details and advise.
To W_PUMP but they are usually adjustable so if your pump needs to run full power you will have to adjust it manually.i have the same problem as op dont know if i should make a new thread but i'll post here first unless some1 tell me to make a new one. my d5 pump instruction say i can connect the pwn connector to my motherboard’s CPU_ Fan or designated water pump header. but my motherboard have a W_pump header and the motherboard manuals say if you have a water cooling kit connect it to aio pump header so which header should i plug my d5 pump to?
But.... yours is more of a custom cooler just in kit form so you may want to experiment with pump speeds.
Some rule of thumb is, if pump is 3 pin, run it at full speed, if 4 pin it's meant to be adjustable.
Yes.mines a 4 pin so it ment to be adjusted right? so i put it in w_pump so i can adjust it?
