Ways to turn off chassis fan?
user
Splendid
Dec 26, 2003
3,943
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
I've been looking around and around and around now for a good application
which can turn off that annoying chassis fan when the cpu temperature is
super minimal. Unfortunately none of these has worked so far. Any
experiences out there on that subject or should I just rip the power to the
noisy thing straight out?
I using the EP-8HDA3+ together with AOpen H600B.
Regards by Ole C.
You could get a Papst Variofan. They do not look at CPU
temperature but air temperature in general. Should be close
enough. Other than that you have to design something yourself,
e.g. Variofan ot other temperature-controlled fan and glue the
temperature-sensot to the CPU cooler, or something like it.
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
even if there is a possibility to use some rpm-reducing software with
your mobo I would recommend replacing fan with a Thermal Control
equipped one (maybe Arctic?) or voltage reducing stuff like Zalman Fan
Mate or home-made solutions with resistors. most fans when runnig 5V
instead of 12V are almost noisless - just be aware that not all fans
start at such low voltage.
> Regards by Ole C.
best regards
Thanks for the response Arno and Lew. In the end I went and bought myself a
fan controller to adjust the voltage for all of the computer fans. The
choise was Sunbeam Rheobus which I must recommend to all users who feel
their fans are making too much noise. With the Rheobus you can also turn off
the fans completely, or adjust the rpm down to a noisy-free level.
All the best regards this time by Ole C.
"<:: Ole C ::>" <olecl-no-spam@start.no> skrev i melding
news:9QwPc.1348$Cc.339721@juliett.dax.net...
the
> Regards by Ole C.
