[SOLVED] Weird Case Model and problems with the power suplly
joriselfferich
Commendable
Oct 3, 2018
12
My brother and I recently put a budget pc together. We waited a few days until everything arrived. But when I looked in the case there were no screws or other thing put in the case and you have to add the power supply above the motherboard. There isn't even a little platform that holds the power supply up. Just a small thingy from the case. I came to the conclusion that you just had to screw the power supply to the bracket. But the case came without screws. Is there any way to fix this problem because I have no clue.
List the models in question to get a useful answer.
Cases often have the screws stored in one of the drive bays if you haven't looked yet.
Some cases don't require motherboard standoffs.
I can't think of a case that doesn't have a mounting mechanism for the power supply, either the standard four screws in the back or a tray you mount it to with a thumbscrew or something to hold it in.
