[SOLVED] Weird Fan Noise
Stormhunt1
32
Hey guys I've had my computer for about a month now and recently my fan has been making a weird noise while gaming, it seems to be coming from the top front fan in my system the noise only started happening with me today and I was wondering if anyone can by any chance be able to pinpoint the issue, I've attached a streamable link that will hopefully help with pinpointing the issue.
https://streamable.com/vop0n
(sounds like the beginning of an old dial up)
Thanks for your help.
PC SPECS:
GPU: ASUS STRIX 5700XT GAMING OC
CPU: RYZEN 3600X
RAM: G.SKILL TRIDENT 16GB
PSU: 750W CORSAIR
MOBO: ASUS PRIME X570-P
FRONT 3 PC FANS: THERMALTAKE PURE PLUS 12 RGB
Use a long cardboard tube or even a rolled up piece of paper to carefully listen around the fans.
Try to find a specific source or location for the noise.
Inspect the area for dirt, debris, cables touching the fans, etc..
Gently tighten the top fan screws - that may make a difference. The screws may have just loosened up a bit.
While inside the case take a look at all other cables and components to ensure that all are fully and firmly in place. Components do creep loose over time due to heating, cooling, and vibration.
