G
Guest
Guest
First I wanted the NEC 19" FE950+ but it seems I can't afford that. So I'm looking at these somewhat cheaper 19". All of them claims 1280*1024 @ 85Hz, but besides that which is the better? I'm not a gamer but I will do some semi-pro graphics working, dtp and photoshop.
The crt's I can choose between are:
Hansol 19" CRT 900P TCO-99 Dot Pitch 0,26mm 2,895:-
Hansol 19" CRT 920P TCO-99 dot pitch 0.26mm Invar Shadow Mask 3,043:-
LG 19" CRT 99G TCO-99 0,26 dot pitch 3,043:-
LG 19" CRT 900B TCO-99 3,143:-
NEC 19" CRT Multisync V921 TCO-99 Dot Trio Mask dot pitch 0.26mm 3,253:-
Hansol 19" CRT 920D TCO-99 Dot Pitch 0,25mm 3,702:-
Hitachi 19" CRT CM-715ET TCO-99 Black Matrix Invar Shadow Mask 0,22 dpi 3,795:-
LG 19" CRT 995FT TCO-99 Flatron Flatron dot pitch 0.24mm 4,514:-
prices are in SEK, just included it for comparision
(100 SEK = 9.50 USD)
<A HREF="http://www.menvafan.net/melc/" target="_new">the Anarchist MelanieC Fanclub</A>
<P ID="edit"><FONT SIZE=-1><EM>Edited by janeM on 04/30/02 10:44 PM.</EM></FONT></P>
