What are Geforce GTS 250 SLI Power requirements
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello I am new here any help quickly will be greatly appreciated
I have a PSU from OCZ
Model number: OCZ550FTY
Wattage 550W
Series: Fatal1ty
I am wondering if I will be able to support 2 video card Geforce GTS 250 in SLI mode
Brand: PNY
Series: XLR8
Model: VCGGTS2501LXPB
Thanks
I'm not trying to be an ass-hole or anything but you could of just googled "GTS 250 power consumption".
I did this for you and came up with;
165w idle
237w load
So if you simple take those amounts and double them you will have an approximate power consumption.
That all being said, every card runs slightly different and your results may vary slightly.
Ah warhead0 I dont know where you got those numbers for wattage since you didnt source them out
as per Nvidia website link found easily by googling
http://www.nvidia.com/object/product_geforce_gts_250_us.html
the max wattage drawn is 150w using one 6pin connector
with 450w for single card recommended
so it would be @300w for both cards
but that is not total system draw
amount of HDs,CPU TDP,amount of Optical drives and addin cards needs to be figured out
this is a decent PSU calculator for determing PSU wattage
it does overestimate a little as all PSU calcs do
but is one of the best
http://extreme.outervision.com/psucalculatorlite.jsp
and warhead0 please refrain from profanity on Toms
at least make it something like butt hole or a-hole
just out of respect you know
I have been know to use a few choice words myself :) LOL
here is toms review of GTS 250
http://www.tomshardware.com/reviews/geforce-gts-250,2172-10.html
showing TOTAL system wattage at
167 idle
237 full load
you would want to look at their test setup to see system specs and compare to your own
but roughly add 150 (single card draw load) to the 237
gives you about a 387 total system load
or about 400w
OCZ makes decent PSUs
so 550w should be okay
though moving up to a 650-700w PSU would give you more headroom
You were right with the total system draw
but it helps to source out your info
and also note whether it is total system draw or single card draw
Its all good :)
and if people would google then half this forum would be rendered useless :) LOL
Yea my CPU is Intel i7 860 2.8GHz LGA 1156 95W
I got about 3 HD one is a 7200 RPM and I believe the other two are 5400RPM
DVD is model: iHAS224-06 Make: Lite on
No other PCI addon besides the graphic cards
in regards to other things, sometimes it is nice to get a some what human response, compared to just reading a website from google. But I did search just wanted to double check with other people out there.
I also like using the forums instead of googling all the time myself
It is especially good to hear from someone who has the same equipment
or been in the same situation
there are certain questions that pop up alot for example
why does my cpu run at 1200mhz instead of 3000 mhz
(intel speedstep or amd coolnquiet are the cause)
which could easily be answered by searching toms or google
but most of us regulars at toms dont mind answering those kind of questions
at one time or another all of us here were "noobs" or beginners
nobody starts off knowing everything
if it wasnt for forums and people asking questions
I wouldnt know half of what I know now
good luck with the setup
BTW you might find this interesting
http://www.tomshardware.com/reviews/gaming-graphics-card-geforce-gtx-480,2598-4.html
discusses SLI 250s
