[SOLVED] What are normal Ryzen 5 3600x temps?
krsensei21
84
4
4,535
Just built my new setup, and I’ve noticed the fan is kinda loud & the temps have been from 40-50 idle & then jumped to 60-70 when I started downloading drivers. Is this normal for the 3600x & stock fan?
Also the fan is like going from quite to loud when I do something simple like open chrome. Also just noticed it sounds like a jet when first power on or down
just wondering if what I’m experiencing is normal with this cpu & stock fan.
Build
5 3600x
asus 1650s
16gb Gskill ripjaws 3200 cl16
Antec 550W gold plus psu
gigbyte b550m DS3H
lian Li 205 case
D
Completely normal, this is typical Ryzen behavior. Set a fan curve on your CPU cooler if you don't want the fans to ramp up like that.
I would also not go with the stock cooler on a 3600X. Try getting something like an Arctic Freezer 34 eSports Duo.
Reactions: krsensei21
Happen to know any links to a good tutorial on how to do that ?
Thanks man! Thought I did something wrong after 7 hours of building lol.
Unfortunately I don't have a link to a tutorial video. But really, look up "Ryzen fan curve setup" and you should find something that helps. You can set a fan curve in the BIOS.
Check out my recommendation above for an Arctic Freezer 34 eSports Duo. Not needed, but definitely unlocks the full power of your CPU. Zen 2 boosts higher with lower thermals.
Sweet thanks for the info! I’ll definitely check out those as well. Appreciate it m8
