What are these connectors, and where do they go? Cosmos II Ultra Tower
Klaleara
16
It has been awhile since I've put together a computer, and I have always had a fondness for far too large of cases, so I got the COSMOS II Ultra Tower.
Issue being, it has a whole ton of connectors that I have no idea where to put them. It is 3 Pin male connectors, in a shell thing (A lot of them, fan connectors), and 2 pin females (A lot of them, LED connectors). I have no idea where either of them go.
http://puu.sh/hDBhI/197564fa5c.jpg (Link is a picture of me holding the connectors)
Any help would be greatly appreciated.
Rampage V Extreme
EVGA SuperNOVA 1300 PSU
More detailed pictures
3 PIN
Front: http://puu.sh/hDGgE/a645850ec5.jpg
Side: http://puu.sh/hDGiH/0c9749b4db.jpg
2 PIN
Front: http://puu.sh/hDGjN/19cd7aa503.jpg
Side: http://puu.sh/hDGlb/fb11a24fb5.jpg
The 3 pin one is for a fan, don't know what the 2 pin goes to, and cant make out what the middle thing is between them (or if it is just the wire of a cable).
Your motherboard, case and power supply should all come with a manual stating what each cable is for.
Stating what the cable goes to would have helped as well as we don't know if it is coming from the PSU, the case or something else.
Yes, yes I did look at the manual. If you looked at the picture, you would have noticed how neither of the connections show up in the manual on page 20 (No 3 pin, or 2 pins show up on page 20 at all).
They do however, show up on page 17 for Fan Controller Operation. However, I'm still lost on what to do with them.
The manual shows me the connections are for (The wires are labeled themselves too), but not what to do with them.
I apologize, both connections come from the case itself, pre-wired in (And quite the mess).
I was holding 3 connections, I'll take individual pictures, and try and make them better. I edited the original post with them.
The Cosmos manual leaves a lot to be desired for such a sophisticated case.
The 3 pin either connects to your board (with a fan extension cable that is female-female), or is for a fan LED switch.
I cant find anything in regards to the 2 pin cable, you will need to trace it back to its source.
The cords are sadly in a gigantic bundle, that go through the back, and back to what appears to be the top portion of the computer. From there, it is impossible to know what these are for.
As for the other guy, what is the actual name for the 3 pin connectors? I don't have any spares, so would have to buy some.
