Question What are these temps in HWMonitor and are they too high ?
Feb 24, 2025
34
Hello, i have been using HWMonitor recently to monitor my prebuilt system as i'm having some performance issues with it, i have noticed 2 temperatures that go higher than anything else and i'm wondering what they are and do they possibly effect my CPU/PCs performance, the 2 temps are PCH from Motherboard and VR from my CPU.
My CPU is i5-12400F which has managed to get a pretty low score of 8,197 in 3DMark Time Spy, i was under the impression that it should be 10-12K.
Motherboard is Lenovo 3741, this is all i can get from HWMonitor.
Prebuilt is IdeaCentre Gaming 5 17IAB7 (RTX 3060)
If need more info let me know.
Here is the Time Spy results i ran few days ago if they show anything useful.
https://www.3dmark.com/spy/53525864
Me again, i have received and installed somewhat succesfully the new parts, only took 2 days and i have never been so frustrated in my life, the worst part was putting the I/o shield to protect the MOBO ports, took like 2 hours because it did not want to go where it needed to go, then had some fan issues and cooler decided to join the party to ruin my mental health.
The case is like 3 times bigger than my old one the size of a toaster, cables are pretty messed up and cooler does not fit with fan lights but i honestly don't care anymore, i'm just happy that i somehow managed to build my first PC pretty much from scratch, performance wise nothing changed but i have access to XMP and a million other BIOS settings which make me happy compared to the... i believe 7 whole settings that Lenovo was offering.
I believe the problem is the GPU, there was quite a long timeframe where the fans sounded like jet engines because it was overheating (my guess) and it did some damage until i changed the dried up thermal paste and blew out the dust, so my next move is grabbing a new CPU/GPU and faster RAM next month, for now i'm more than happy with what i got.
Appreciate you for trying to help :)
(Looks a million times better than the old PC which i put a picture of above!)
Reactions: Flayed
Nice job man.
So, couple of questions because it's kind of important AND might be directly related to any problems you are having. Being as you have a new motherboard, did you do a clean install of Windows and then go to the product page for the new motherboard and download the latest chipset (.inf), networking adapter (LAN and WiFi (If equipped)), sound and if equipped, bluetooth drivers, and install them?
Did you download the latest Nvidia drivers directly from Nvidia and install them? Do you have afterburner or another GPU tweak program installed so you can control the fan behavior on the graphics card AND do you have that tweak utility set to start with Windows and reside in the system tray? Because if you don't have a tweak utility for the graphics card installed your fan noise issues are likely directly related to that, and if you do, but are still having issues, it's likely because you don't have the GPU tweak utility set to start with Windows and just run minimized, which is necessary if you want the settings to stick. Stupidly, none of the GPU tweak programs can keep their settings in effect if you close the program. The second you close it, those settings are out the window and the card will revert to it's stock hardware level behavior.
If you didn't do a clean install of Windows and are using the installation you already had from before you got the new hardware, especially when it comes to the motherboard and even more so when you go from one chipset to a different chipset, even if they are from within the same generation, it's a really good idea. Plus, having installed a new motherboard, if you didn't already, whether you did a clean install or not you might want to check in Windows settings and see if it's still activated. Usually when you change motherboards it deactives Windows and you have to jump through a few hoops to get it to reactivate by telling it you've installed new hardware. Good idea to also ALWAYS attach any Windows licenses you have to a Microsoft account that is attached to you, so you can move qualifying OS licenses from machine to machine (Motherboard to motherboard) when you do upgrades.
Nice job man.
I did not perform a fresh windows install, not too long ago i got a 2TB SSD upgrade and it took like 5 days to install it full of games, not really looking forward to redoing it unless its guaranteed to do good towards my PCs performance, i downloaded Armoury Crate and it had some updates in it thats pretty much all i did, it had bluetooth and some other stuff in it not sure about the chipset stuff, this is all i updated below + some windows update stuff.
I only download drivers for my GPU through the NVIDIA App, i uninstalled with DDU i think and downloaded from their website directly like a month or 2 ago, i also tried using Afterburner few months ago but i was not comfortable messing around with it and risk damaging something so i only used its overlay to see system performance.
I grab Windows 11 to my USB drive and have it ready incase i need to do a full reinstall, only thing that happened is it asked me for my Bitlocker passwords when i moved over to this case and i had to delete volume on the other M.2 SSD i swapped for the 2TB one cause old MOBO only had 1 M.2 slot and formatted it afterwards, the loud fan thing happened and caused my PC to turn off after 2 minutes by itself, i reseated the RAM a few times because theres only a clip on 1 side that you push to secure the RAM and i was hesitant at first, right now the 3 fans i installed to the bottom run at 1,000 RPM while all others run around 750 RPM, it sounds like it keeps changing from 1,000 to 1,200 and is making a bit noise i don't know why, temperatures are awesome and when i had the window panel open the cool air blasting out this case is ridiculous, ain't nothing overheating in this thing, i could use it during summer to cool me off.
Oh, and apart from the fans everything is working surprisingly well, i only had to google about 2 cables and the rest i was able to figure out where they plug in, still would never do it again, i would rather go back to the lenovo toaster than install 1 more I/O shield.
not really looking forward to redoing it unless its guaranteed to do good towards my PCs performance.
It 300% will.
Oh, God. Sorry, but that crap (And Dragon center (MSI), each motherboard manufacturer's "bundled" utility for that matter) is the last thing you want to put on your system. Get it off. ANY driver updates you should download and install manually directly from the product page for your motherboard or other hardware, except for AMD chipset drivers. Those you should get directly from AMD no matter who the board manufacturer is. For graphics cards, directly from AMD or Nvidia, no matter who made the card. I can SHOW you at least 50 threads I've worked, plus can attest to my own experiences on the bench, where simply having one of those installed was the entire problem and removing it completely cured whatever issue they were having. They are like intentionally installing a virus, much the same as half the pre-installed crap that comes on OEM systems.
Using the built in options in the Nvidia installer and choosing clean install seems to work pretty good now. I'd do that most times. I'd only use the DDU if you have a problem that seems to be GPU related and nothing else seems to work. DDU is very good, but not always necessary these days if you use Nvidia or AMD's own clean install option.
WHICH DIMM slots, EXACTLY, did you install the memory in and YES, it absolutely does make a difference. Also, without having to go back through the whole thread, did ALL of the memory come together in one kit OR do you not really know for sure if it came with the system because OEM builders often will just slap crap together not caring about that part, which can mean a variety of issues, or none.
I'd really suggest starting from scratch, BUT, if you are planning to upgrade the CPU and memory soon, it might be worth waiting until you do that unless you don't mind having or maybe needing to install Windows twice. Surely you don't need EVERY one of those games installed right now AND more importantly, why are your game files installed on the same drive as your operating system? Not a good way to do it. Things you don't want to lose, and game files, should almost always be on a separate drive AND you should ALSO have ANOTHER drive that has those same files backed up to it in case something happens to the drive which it will. It is NEVER a question of IF, only WHEN, when it comes to drive failure.
It 300% will.
There are 4 DIMM slots, i put my RAM in slots 2 and 4, this memory is a 2x16GB kit which i bought separately to replace the prebuilt memory.
I also have a terrible attention span when it comes to games which causes me to swap between them constantly, i would say from the 61 games i play probably around 50 pretty regularly, also both the M.2s are loaded full with games, the main 2TB one only has like 50GB free so i had to start using the old 512GB one too, i spent so long with that crappy 512GB one and had to juggle games back and forth and its SO nice just downloading everything i want to play and actually get to play them when i feel like it instead of waiting a longtime to download it, by the time it's done i don't want to play it anymore.
I could try to do a fresh install now and see if it does anything, because i might buy a third m.2 SSD.....for more games and that would probably be another 1-2TB so better now than after and see if it changes anything, maybe it can save me some days worth of downloading games after i upgrade, also is having a Windows 11 installed to your USB drive not enough if something happens and you need to reinstall windows?
Wait. What?
Yeah, so i reinstalled last night i disabled one of my M.2 drives because i was too lazy to take it out and leave only 1 because apparently it causes issues if you have more than 1 in your PC because windows might try to put the files in a random M.2 SSD, worked perfectly and i installed chipset and some stuff from Asus website for my MOBO and did not get Armoury Crate, did clean install of GPU drivers and let the windows updates go through.
About the windows USB thing apparently i was incorrect, i never knew you have to buy a new licence if you swap motherboards because i never had it happen to me and i never heard anyone talk about it so i just assumed when you download it to your USB Drive and change your PC to boot into it so it starts you fresh and installs Windows 11 again to be the same thing as having the licence, but i was greeted by a product activation page when i reinstalled, i just clicked i don't have a product key and it let me select Windows 11 and proceed so i guess it worked without a key, no activate windows watermarks or anything on my screen.
Now about Performance, i had around 140-220 FPS in Counter Strike 2 which is where i like to get that extra performance in BEFORE the full wipe, now after playing for around 15-20 minutes i have 134-204 FPS, same competitive settings, same map, same areas of the map, i assume by time it will get back to 140-220 as i keep playing but basicly getting the drivers and reinstalling did nothing for my performance as i thought, it seems like changing resolution does nothing, reducing graphic settings does very little, reinstalling does nothing, i guess i will still continue to blame the GPU since it is the only thing i ever had problems with in the past, my CPU has been fine always so i can't blame it, i might concider ripping this card open and try to remove the stripped screw since i now have like 20 different types of screws leftover from this build (and i have a screw kit i randomly ordered earlier) maybe theres a replacement and i can clean the fans for the first time in..... 2 and a half years?
(Last time i tried to clean my GPU, no kidding i lightly shaked it facing the fans down and a pile of dust just fell to the floor, i feel like cleaning could do something if i can get in there)
EDIT: I also opened HWinfo and i see that my GPU has a thermal limit at 83℃, my GPU hotspot temp jumps to that in like 1 minute of just being in the game lobby, regular temperature max got to 72.4℃
Another edit: i attempted to swap the paste in the GPU and clean off dust and of course that went wrong, i managed to snap a black wire which destroyed 1 of my 2 GPU fans and now all that was for nothing, luckily i have 120mm fan below each GPU fan and i can just crank their RPMs a bit higher and pray that it solves this until i can get a new GPU, those wires were superglued in there and i tried to be very careful with them because i know people mess up with those cables, also i stripped 2 more screws so now 3 are broken on top of the wire.
I guess in the future i should maintain my hardware more regularly to make sure the cables dont get stuck like this and caked up with dust etc or just take my stuff to a repair shop, if i was patient enough i could pull the wire with pliers or something and place it back to its socket and hope that it helps temporarily but for now i'm going to test and keep my eye on temperatures of my GPU to make sure its fine without the fan.
Well, sometimes it doesn't right away but might show up at some point. I'd check which is easy enough to do.
Open Windows settings.
On the left side click on System.
Click on Activation.
You will see "Activation state" and it will tell you whether your system is currently activated or not. If it is not, it should offer options to fix that including "I recently changed hardware".
it says Windows 11 Home Activated.
Also do you think that constant 78.6℃ GPU temp, 95.3℃ Hot Spot temperature are an issue while gaming with 1 GPU fan broken and 83.0℃ thermal limit?
Wait. One of the fans on your graphics card is broken? Did you mention this previously? Yes, I think you are running too hot because "max safe hotspot temp" is realistically considered to be around 94-97°C. You are literally a few degrees below throttle temp AND you might only be at that temp because it IS already throttling.
Run something that puts it at the max temp you are seeing and take an HWinfo screenshot of the GPU sensor readings so we can see if it indicates throttling.
No i broke the black wire inside my GPU when i opened it today to try to clean the dust from inside it, it was superglued stuck in there and i tried to be delicate with it, i might be able to pull that wire back into the slot it was in and maybe it could work.
New hot spot max is 97°C and normal GPU temp 79.1°C, no performance issues so far when it gets that high.
Yeah, I'd say you need to fix that AND if you can't, I'd pull the card out, take it to any reputable local electronics repair shop and have them fix it. Shouldn't cost more than 50 bucks for any repair of that type which is a LOT less than replacing a card. But if you can do it yourself that would be much better. Why did you try to open the card to "clean dust"? Just use an air compressor or a can of compressed air that you can buy at any home center or places like Walmart. Even Staples and other office type stores carry it. Like five bucks. Done. No broken wires needed.
This card is like 2 and a half years old, the dust is so thick it does not come off with compressed air and i can see humongous piles of dust in the fans, also i just attempted to open and fix the fan cable and managed to break a red cable this time lmao, the GEFORCE RTX 3060 LED label is now broken and i'm going to quit before i have no GPU left, i got the black cable back into it somehow but it did not fix it.
Amazing how i continue to break stuff even when i don't even touch em, that red cable was nowhere near where i was working i just heard a little snap and it wanted to come off, luckily it was held in there by a thread so i just put the screws back in and threw in the towel.
I am not going to bother with this card anymore and i will just roll with it untill i can replace, currently i'm thinking about possibly a new RTX 3060 but one that is not shipped with a prebuilt, i heard these have less performance than the real things not sure how true that is.
Another choice is to move up to a RTX 4060 16GB and pair it with i5-12600K, i could get like buy now pay later kind of deal and pass the whole package to my older brother, then it will be his problem to fix the card and maybe get himself a entry level PC for 50 euros + 70 for a NVMe.
What? Are you running in this in the back room of a Burger King? LOL.
I'm sorry, I don't mean to be a jerk, but I feel like it's actually an honest question. I have cards that I've run in systems, and ARE still running in systems, for more than five years, and they get used a lot for regular stuff, gaming, tests, benchmarks, etc., and they don't have that. So.
Reactions: bit_user
Are you using compressed air in a can? If you are, honestly those things aren't worth a pinch of . Not for caked on dust like that, there's no pressure at all. An actual compressor would do the job.
I don't agree. I mean, I'd agree for a system that needs to be "cleaned". But as a maintenance procedure, the pressure in those cans should be MORE than enough. In fact, I've seen them cause issues that were not there before when used full strength and by somebody who didn't understand HOW to actually use them. If it's beyond a can of air to fix, then you have MUCH bigger issues.
Reactions: bit_user
My experience using air in a can wasn't great. Just wasn't enough pressure or reach to do any meaningful dust removal from the depths of heatsink fins, maybe it's enough removing light dust from fans. Compressor can do damage i agree, if using nozzle too close or pressure too high, or moisture. But these concerns can be mitigated. Nozzle not too close, pressure not too high and using a moisture filter, though, buildup of moisture inside tank can be helped by leaving the valve opened after use.
I guess this might be a little too much for OP to consider.
I used a can of air to clean out the airpath of my Dell Precision HX/dGPU laptop, that I use for work. The air can was maybe 70% full, but definitely not new. Even that was enough pressure to push one of the fans out of its groove so it now makes a whining noise when it spins up. Because it's a work laptop and still under warranty, I don't want to open it up to see if I can move the fan back into place. So, I have to just live with the noise for another year and a half (until the lease is up and I get a new one).
So, even when canned, be careful with compressed air, people.
Compressed air cans kinda suck cause you can't really tilt them to get the dust off from hard to reach areas, some liquid sprays out of it if you do so or use it for too long at once and this brand that i use the nozzle thingy falls off very easily if you even touch accidentally something with it, watched a video about best PC cleaning tools not so long ago and i remember these being brought up somewhere in the video too.
As for the dust i have usually done what i can and use Q-tips to carefully swipe off the worst of the dust that can't be blown off by compressed air cans, obviously not possible for the GPU fans since i can't get the bottom plate off to clean it but i have tried from an angle to remove what i can.
Also any recommendations for which manufacturer RTX 3060 12GB or RTX 4060 16GB card i should go for? Asus, Gigabyte & MSI are pretty much all the options from what i have seen in stores here, from my understanding Gigabyte seems to be cheaper than the other 2 that is about the only difference i can think of.
Reactions: bit_user
I bought this a while ago and it has probably already saved me 30 dollars on compressed air. Is this air duster at a practical price for someone who uses canned air once every year or two? No. It's also 20 bucks off on their website right now at 80 dollars. It is also about 20% stronger than compressed air at its highest setting. The main thing about it that I like is that it has a similar strength as canned air on its middle speed setting at probably 5 times the CFM so I get done dusting a PC so much quicker. There are a few review on it since I got it that are pretty favorable.
Reactions: bit_user
I think this may be one of my final comments in this thread, i just ordered a brand new RTX 3060 from Gigabyte, same 12GB of VRAM and i will be slapping that in my build around 21st this month was estimated time of arrival, i was gonna grab a RTX 4060 but then i realized... i don't want to pay that much 😀
I have paid so much money just to pretty much build a new PC, the only thing from my old case is the CPU after GPU gets upgraded and the 512GB NVMe as secondary SSD, when this card arrives and i have it installed i will return for one final update as i believe all my problems have come from the GPU, i mean changing settings and resolution and doing all types of stuff and they don't change my FPS like at all, i have repasted my CPU and taken good care of it so know it is not the problem, CPU temp is also incredibly low.
I have changed RAM also and that was not the issue, i shall be back with good news!
I've seen those, but I only use about 1 can of air per 2 years or so. It's not worth it, for me. Most of my PCs have dust filters on the intakes and use positive pressure, which means my main uses for it are for other things.
I use it at work and it blows the dust right out the filters, no need to give the filters a bath. For me, its going to save money in the long run.
Reactions: bit_user
Honestly, I was just kidding man. My apologies that you seem to have not taken it that way. Totally my bad I guess.
For what it's worth, I wondered the same thing.
I've had good experiences using cases with removable dust filters over all the intake fans. I suppose it depends on the kind of dust, though. If there's a lot of fine dust where you are, then the coarse mesh they typically use for this probably won't help much. The type of filter material used in HVAC systems would be much better, but now we're talking about rigging together something very ad hoc that could not only be unsightly, but also might not work very well if you're not careful to make sure it's not leaky.
Anyway, good luck. New build looks nice!
