What build should i go for?
Scythe_1
5
Current Build:
i5 3570K @3.4Hz
GTX 760
8 GB RAM
650Watts
Asus P8Z77-M
Possible Build/s:
(Different GPU)
i5 3570K @3.4Hz
GTX 980 TI G1 Gaming
8 GB RAM
650Watts
Asus P8Z77-M
(- the GTX 980 TI)
i7 4790K
GTX 970 Strix
MSI z97 Gaming 5
8GB RAM
650 Watts
Here's a start
× GA-Z97X-Gaming 5 Gigabyte GA-Z97X-Gaming 5 ₱8,090.00
× intel i5 Intel Core i5-4690K up to 3.90GHz (Quad Core) Haswell Refresh Processor ₱11,090.00
× Sapphire R9-380 NITRO Sapphire R9-380 NITRO 4GB 256Bit DDR5 ₱10,699.00
× ripjawxred16GB-8gbx2-ddr3-1600 Gskill RipjawsX 4GB Dual 1600 CL9 (F3-12800CL9D-4GBXL) ₱1,690.00
× Crucial BX100 Crucial BX100 250gb sata (CT250BX100SSD1) ₱4,300.00
× WDBlue1TB Western Digital Caviar Blue 1TB ₱2,499.00
× CM N600 Cooler Master N400 Clear Side +2 Fans Casing ₱2,740.00
× Seasonic S12II-620w 80PLUS Bronze Seasonic S12II 620W 80PLUS Bronze ₱3,150.00
× Internal LiteOn IHAS124 24x Multi Format DVDWriter LiteOn IHAS124 24x Multi...
Sorry but what do you mean market?
Gaming
I wanna run everything at 1080p 60fps if possible
What part of the world? Eurozone, North America, South Asia, South America..... you have mentioned some general parts and there are others not mentioned. Your PSU needs to be high-performance, you need a CPU cooler for the i7 if you plan to overclock, and I would choose a different motherboard for better power phases.
980ti is total overkill for 1080p 60FPS, you will not be using it at anything like full power. It will run 2k well, and 4k just barely.
GTX970 is excellent for that level.
I'm from South East Asia. I'm thinking of getting a H100i GTX for the i7, you're right 980ti is a overkill. I might change the CPU from i7 to i5 4690k. What do you recommend for me to go for?
Here's a start
× Internal LiteOn IHAS124 24x Multi Format DVDWriter LiteOn IHAS124 24x Multi Format DVDWriter ₱850.00
Subtotal
₱45,108.00
Needs OS and CPU cooler.
