[SOLVED] What cable do I need?
Jun 11, 2020
15
The GPU has a DVI port but the specs for it do not list which type and DVI has thre options. Analog only (dvi-a), digital only (dvi-d) or both (dvi-i)
You'll need to find out which type your monitor supports and match the cable and GPU with that.
