[SOLVED] What cable should i use to achieve 144Hz?
Nov 30, 2019
My laptop has a mini display port. My monitor only has HDMI and Displayport. What cable should I buy to get the full 144hz? Currently, i'm using an HDMI cable, and am only able to achieve 100Hz.
A mini display port to display port adapter should work (to use a displayport 1.2 cable), but if you're unable to go down that route, buy an hmdi 1.4 cable and you should be good.
(i had the same issue before i got my pc)
