I have heard here on the forum that when using push-pull cooling on an air cooler, that they should not be matched. That the exhaust should have higher CFM than the intake; which in turn should have superior static pressure. First, is this true? Second, can someone recommend a good pair of 120mm fans?
They will be used on different coolers over time. Hyper 212 Black Edition now, but others as well.
2nd question: Is latest version of Prime95 safe for 9th gen i5/i7 CPU stress testing, or should I stick with version 26.6 like I did for Haswell?
