G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware (More info?)
I just installed a USB hub. WinXP (SP2) immediately detected it
and a bubble popped up to inform me that a "Generic USB Hub" had
been detected and drivers were being installed.
The hub works and the Device Manager does indeed show a new
"Generic USB Hub" in the "Univeral Serial Bus controllers" section.
However, the Device Manager also shows another new entry in the
"Human Interface Devices" node called "USB Human Interface Device".
This item has a yellow exclamation point:
http://www.grog.net/~derek/acdusb.gif
And when I right-click on "Properties" it says:
"This device cannot start. (Code 10)"
Since my hub works, I'm not exactly sure what's broken. What is
a "USB Human Interface Device" and what would it be doing if it
had started? I'd like to understand exactly what's failing to
start and why. Thanks.
P.S. This USB hub is integrated into my 23-inch Apple Cinema LCD.
Apple provides no USB drivers with their displays. Other WinXP
users have reported the same behavior with this display, so it's
most likely not related to my hardware configuration.
