I haven't built a computer in 15 years, and just built one with a Ryzen 3 2200G, stock cooler, sitting on an Asus ROG Strix B450-F Gaming mobo, 2x8Gb Ripjaws 3200Mhz sticks, all in a Corsair Carbide Series Spec 01 (which was evidently a poor choice for aftermarket cooling as it specs out no more than 150mm radiator height). I am getting some high temps (85 C on Package temp per HWMonitor while running Prime95) with moderate voltages (1.425 on CPU, 1.35 on DRAM, and as low as 1.20 on GPU side). When starting Prime95 the CPU jumps almost immediately from between 35-40 to 65 or so. SO - I have limited myself in choices, and primarily am looking at the EVGA CLC 240 to top mount, or the Noctua NH-U9S, unless someone has a better solution. The top-mounted AIO would be nice since I have 3 case fans and 5 spots on case, but that isn't a deal breaker. Need to keep solution under $100 though. What is my best solution, temperature being by far most important?
