Question What is normal CPU temp for an I7 11700k?
Use Celsius for computer temperatures.
212F = 100C
Your CPU is overheating and thermal throttling. What CPU cooler do you have? The 11700K can put out a lot of heat depending on what games or apps you are running.
It’s an IBuyPower AIO. I’m not sure the exact model because it was bought as a pre built from Microcenter.
