I have MACBOOK AIR 2017. My current Mac's 128 GB SSDs reading speed is 1257 MB/second and writing speed is 430 MB/second checked by "BlackMagic Disk Speed" app store app.
I wanted to upgrade the Mac's SSD from 128 GB to 512 GB so I purchased "Samsung 980 500GB Up to 3,500 MB/s PCIe 3.0 NVMe M.2" from offline store. It does not support directly to SSD socket in Mac Book Air 2017 so I also purchased it's converter "Buyyart PCI Express 2013 2014 2015 to M.2 NGFF SSD Adapter Card for Air Pro MacBook" from Amazon.
Samsung 980 500GB SSD/NVMe:
https://www.amazon.in/Samsung-500GB...5&sprefix=samsung+evo+980,aps,479&sr=8-1&th=1
Supported Adaptor:
https://www.amazon.in/gp/product/B0...43a3131107a53&language=en_IN&ref_=as_li_ss_tl
I have installed both the devices properly and also setup operating system on Mac. Everything is ok.
Then I tried to check the read / write speed this newly installed SSD. According to Amazon, speed will be approx. 3500 MB/s but unfortunately when I checked it with the same software "Black Magic Disk Speed". It shows 850 MB/s as read speed and writing speed is 550 MB/s. Both read and write speeds are very low.
Here I have a query that Is low read and write speed reason using connector between Macbook and SSD? Kindly suggest me what is the reason and how can we fix it. Thanks a lot.
Supported Adaptor:
