[SOLVED] What is the best SSD for using in a system doing block chain work with RAID?
jlandi
69
Hello all,
I am looking working on a sensor monitoring server that is using block chain as part of the system. Bit of an oddity I find myself in because I have not used blockchain in any form with SSD or RAID environments.
I bring that up because I will be doing a lot of writing/reading from the hard drives and I can't use spool hard drives in this situation.
Right now, I am looking at using the Intel D3-S4510 Series SSD SSDSC2KB as my storage device in a RADI 10 setup.
My motherboard is a SuperMicro X11SCA-F and the RADI will be hardware level.
From my calculations these bad boys would take over 10 years to fail in a non-stop writing/reading situation, but I am only an amateur in these areas.
Thank you in advance!
And you've not specified the actual write cycle rate.
How much will be written on a daily basis?
If it is rarely written to, then you may well get a decade out of it (no guarantees, though)
If you're writing 200GB per day, RAID will not save you.
I would not count on any drive(s) lasting 10 years.
Two immediate thoughts:
1) unless I am missing something RAID is not necessary. Just adds complications.
2) a SSD would be used just if it were a HDD. Just simpler, faster, cooler, quieter, less power consumption.
If failure is a concern, that can be mediated with a good backup and recovery plan.
There may be other thoughts and comments posted accordingly.
Hey @USAFRet! I think you replied to my questions way back when choosing the array!
To answer your questions @Ralston18 and @USAFRet, the sensor server is being put into a spot whereas I cannot easily access it (https://forums.tomshardware.com/threads/using-ssd-slc-storage-with-raid-10.3558595/#post-21486089 ). The reason I was going with RAID is to ensure continuity and to try and get 10 years out of the single unit. Either way, I am planning on having a cold spare installed with the sensor server encase the unit goes belly up regardless.
I heard that the RAID and Blockchain can cause excessive wear on the SSDs; however, I am not sure if that is a myth because all the research I have read online never brings it up.
@USAFRet When I monitored the system last time the majority of the work for the system is occurring in the ECC RAM and not the HD.
I am not 100% sure of the writing and would have to go back to the Cockpit logs to verify. Sounds like (from a hand wave perspective) we are good.
Thank you!
