[SOLVED] What is the cheapest pc build guide you can make that can power a 1080ti?
Feb 12, 2020
Hi, i'm currently trying to build myself a system that can power a 1080ti with no bottleneck. This means that I really only want help with picking out the case, CPU, PSU, RAM, CPU cooler, and mother board. I am going to be purchasing a used 1080ti so the GPU is not an issue you need to worry about. I just want the cheapest system that can power the 1080ti without it bottle necking. Thanks :-D
PCPartPicker Part List: https://pcpartpicker.com/list/hhDJx6
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($73.99 @ Newegg)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($83.98 @ Newegg)
Total: $447.95
Generated by PCPartPicker 2020-02-12 20:56 EST-0500
Total: $447.95
Cheap does not relate to good.
Consider a guideline for a balanced gamer that budgets 1/2 the cost of the graphics card for the cpu.
The characteristics of a good cpu will depend on the types of games you will play.
Some games are graphics limited like fast action shooters.
Others are cpu core speed limited like strategy, sims, and mmo.
Multiplayer tends to like many threads.
