[SOLVED] What is the difference between 9400F and 9400 normal?
The 9400F is exactly the same thing as the 9400 except the IGP is permanently disabled.
Power-wise, there will be little to no difference between a 9400 with the IGP disabled in BIOS and a 9400F, power to the IGP part of the chip is gated off either way.
Means, that, theoretically speaking, it should generate less heat, consume less, have some more room for overclocking and most of all, be cheaper.
theoretically.
But what is practically Intel UHD Graphics? Is this proccesor good for future? I see that it is a little bit better in gaming than the 8400 in gaming. I will use it strict for gaming and a little bit of browsing if this will be my purchase.
