Question What is the difference between NZXT H510 and NZXT H510i?
Belugamer
8
I am planning to buy an nzxt case and doesn't know what to buy between Nzxt H510 and H501 because i don't know the differences
Compare the specs:
NZXT H510i
NZXT H510
The H510i includes:
1x front USB 2.0 port.
Smart Device V2 which includes:
3x Fan channels with Max 10W per channel output*
2x RGB LED port support up to 4x HUE 2 addressable LED strips or 5x Aer RGB or Aer RGB 2 fans
Built-in noise detection module
Integrated LED strips
GPU Vertical Mount.
Aside from that, the two cases are identical. If you don't need a front USB 2.0 or RGB (I can't wait until that fad dies off), then I see no reason to spend the extra $30 for the H510i
-Wolf sends
