Question WHAT IS THE PROBLEM WITH MY MONITOR.
Dec 20, 2020
25
I really don't know what this is because this has never happened on my monitors before. It looks like a halo around the edges of the screen. It disappears in maybe an hour or less. And some times when I boot up the pc and the boot up logo comes out, its all in negative. All I want to know is, is this permanent or is there a fix to this. TIA!
I cant show you pictures because I really don't know what to search for. hahaha
lvt
Commendable
Apr 19, 2021
1,724
276
1,640
39
Could be static electricity, remove the VGA cable from both monitor and computer for a while then connect it again.
If it doesn't fix, maybe your screen has a hardware issue.
Reactions: ninthcloud
Dec 20, 2020
25
thank you for replying. should I try changing the hdmi cable? its already loose when I checked it (the tip, not the port) because of the weight of the cable itself.
hang-the-9
You can take pictures of your actual screen, no need to find other pictures.
Is it a new monitor? Have you contacted the monitor vendor support? Tested with another cable or port?
