What kind of air coolers will fit in a Corsair 250D case?
dalethezombie
69
Looking to buy a new air cooler for my i5 4690 but I'm not sure what to get because I do not know which ones will fit in the 250D case. I'm looking at the Cooler Master Hyper T4. Does that one fit in this case?
According to the corsair website, the maximum cooler height in that case is 95mm. Which means that the hyper T4 will not fit.
I would recommend getting an AIO water loop like the corsair H100i. The 250D was designed with these types of coolers in mind.
If you must go with air, the Notcua NH-L12 would be a good choice.
