[SOLVED] What kind of Sata Cable i need for this Hub?
Dhritimaan
14
Hey Guys,
Recently ran into a stupid probelm. Got a fan set of corsair Sp120 and found out there is no fan hub but a RGB hub. So I knew there is a Fan hub with enough connector in my Fractal Design define R6 stock fan hub in the back. But found out there are 2 segments. The 4 pins are pwm (which it only have 3 slots) and the 3pin Fixed RPM (it has 6 slots of these). I thought the front fans i can transfer to the 3 pin connectors and connect the rgb fans to the pwm pins but found out there is no sata cable connected to the HUB. I want to buy a sata cable. But cant find out what kind of sata cable is this? Ive seen molex sata connectors. but Have never seen this kind of out from fan hub.
Here is a image from the manual. (the red one i want to buy, the blue one is the PWM connector.) :
View: https://imgur.com/a/4miV0ZS
Here are my case hub imgaes : View: https://imgur.com/a/iwHBMrS
Thanks in Advance
