Hello Everyone
It's my first time using a liquid cooler, I have managed to get my hands on a 120mm Radiator, a CPU block, a pump and a couple of pipes. The paste I'm using is Arctic MX4. i7 4790k is the processor and Asus Maximus VI is my motherboard. It's my new gaming build and I'm planning to OC my processor and that's the only reason I've bought Maximus VI. Okay so right now I am using Car Radiator Coolant in my loop and I'm not satisfied by the results 🙁 Here's the link to coolant: https://www.daraz.pk/products/guard...a0e.searchlist.list.4.3a337b7eRz111K&search=1
It's an open air build, room temp is 25C~29C, CPU is running 40C at idle and mid 60s while Gaming when the usage stays below 50% but for example, in NFS Heat, the usage goes up to like 90% and then the temps are 85C~90C 🙁 The radiator's fan is running continuously at 100% speed but still I'm not able to get some good results. Is there something that I'm doing wrong? Kindly help. A friend of mine (still runs a core 2 duo xD) gave me an idea to try Distilled Water i.e. used in Car/Bikes batteries. Should i try that as well? :/ Here's the link to "that" distilled water: https://www.daraz.pk/products/batte...0e.searchlist.list.10.48d278deH1aknl&search=1
If you guys need any more info, kindly let me know. Thanks in advance. <3
